DIY Air-Fuel Ratio Display
found this link. It's about how to do a low budget (about $4) AFR display.
here is the link:
http://www.scirocco.org/tech/misc/afgauge/af.html
here is the link:
<div class='quotetop'>QUOTE (Zenador)</div><div class='quotemain'>Has anyone tested this? I built one (cause it was fun - Geek) but need to know which line off the O2 sensor is the signal wire... its on an 04 I4 Tib...
Thanks...</div>
We wouldn't know mang, we deal with RD series Tiburons, 1996-2001.
Someone make me one.
Thanks...</div>
<div class='quotetop'>QUOTE (javageek)</div><div class='quotemain'>Maybe with it hooked up it is not allowing the ECU to get the signal. Where did you hook it up at?</div>
you should just tap the wire, not cut it out from ECU.
