DIY Aftermarket Steering Wheel
Anyone have an install guide?
I tried pulling out my stock steering wheel today, I couldn't get that fugger off. Is there more than just that one 22mm nut?
Any help would be appreciated.
col96fx, thanks, I took a glance at webtech earlier and it wasn't really clear to me. To be honest I was probably too lazy at the time to really look at it carefully. Not really sure what you mean by "the wheel locks onto a taper" though.
he means that you need something with mechanical action to get it past the point to pull it off.... normally with threads, like a steering wheel puller.
8^)
you can find them pretty cheap at a parts store. i just got a puller at the dealership actually for like.... 4 bucks?
8^)
<div class='quotetop'>QUOTE (insomnia)</div><div class='quotemain'>col96fx, thanks, I took a glance at webtech earlier and it wasn't really clear to me. To be honest I was probably too lazy at the time to really look at it carefully. Not really sure what you mean by "the wheel locks onto a taper" though.</div>
You will find that steering colum & wheel have tapers in them so when you tighten the nut, the tapers are forced together and they stick/lock to each other.
