Cruise Control Install?
Guys you would have to change many things in order to install the OEM Cruise control.
It would be easy if you could get a scrapped hyundai and take it from there.
And also the Combination switch would also have to be changed.
There is also a sensor on the clutch and brake that disengage the cruise so i think installing would be PIA.
But then for you guys that are adament to get it i think the best step is to find a tib with the cruise that is being parted out.
The Dash usually has a main cruise swith and then the combination switch has to be changed
as the rest of the controls are on you combination switch.
Also get the throttle body from the donor car as it uses a double pulley on 1 shaft.
Dont know if that makes sense.
Just my 0.02
Just my 0.02
