Clear Corners: Diy With Pics
Old Oct 1, 2006 | 09:41 PM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
hey socks, i followed your directions and the 'glue' doesn't really ease up, so i ended up cracking part of the plastic cover. is there a trick to remove the plastic cover more easily?
and also, because the 'glue' didn't ease up, i had to use epoxy to put them together. now there's water leaks in my corners. how would you go about fixing that?
Old Oct 1, 2006 | 10:06 PM
xxxmonoxidechild's Avatar
hmm,if i had any idea where my stockers were, id try this, the darker corners look decent on the cobalt blue. if i run across them, im gonna try this, then just swap between the kspecs, and the tinted when im bored. lol
Old Oct 2, 2006 | 05:28 PM
well you have to be REALLLY careful.. i got small cracks in both.. use silicone to seal em... and then to seal the crack, use flowable windshield silicone, thats used to fill in cracks and stuff.
it sux, but u need to be SUPER careful when cracking off the lenss..
Old Nov 29, 2006 | 02:10 PM
Dark2400's Avatar
For clear corners, do you need special corner lights? because mine look like the reflector is the entire part, rather than just a piece inside.
Old Nov 29, 2006 | 03:49 PM
this is for rd2s only.
Old Mar 20, 2007 | 05:11 PM
aaronk19's Avatar
So getting the one visible screw out is all it takes to remove the corners?
Old Mar 20, 2007 | 06:57 PM
^^ Yeah, that and a plastic pressure popper. You have to pop them out of place after you remove the screw. don't forget to remove the light.
Old Dec 19, 2007 | 11:38 AM
jbarham's Avatar
I may have to try this when I get some free time. Your car looks great with the black housings.
