Amplifier Wiring » From Engine Bay To Boot
Old Apr 21, 2006 | 01:50 AM
fonseca's Avatar
If you're going all the way to the trunk, you may as well go with 0 gauge IMO. Then if you ever relocate your battery, or just add a second one, you won't need to upgrade.
AND 0 gauge is not much more expensive than 4.
Old Apr 21, 2006 | 10:06 AM
fonseca's Avatar
I'm not criticizing at all, in fact it's much cleaner because the wire leaves the engine bay right beside the battery, instead of having to find its way to the firewall in plain sight.
Your detailed pics will be helpful for many people.
Old May 5, 2006 | 02:38 PM
It's a longer method, but a usefull contribution to the site none-the-less. Someone should post pix of drilling method with site selection.
Old May 5, 2006 | 05:43 PM
good job man. i got a 0 gauge, 8 gauge, and a ton of 18 gauge wires running through that one and some other wires through the one on the other side.
Old May 5, 2006 | 06:53 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Old May 8, 2006 | 11:09 AM
xxxmonoxidechild's Avatar
ive beentelling people about this way literally for years. this is the only way i know thats possible to run 0/1 gauge without drilling.
also, u did alot more work then needed. u DO NOT need to remove the fender to go this route. ive installed mine, removed it, and reinstalled it using 0/1 gauge and never touched the fender. i used a yard stick to manuver it towards the hole next to the battery.
Old Oct 28, 2006 | 10:24 PM
Tiburonmoo's Avatar
Vehicle: 2000 Tiburon
Anyone maybe have the missing pictures for this DIY too?
