.25 Cent Mod Diy Soon
Old Sep 15, 2014 | 08:40 AM
zoned019's Avatar
Vehicle: 97 Tib
I went so far as to get cables and the shifter baseplate from the GK and swapped them in. It helped a tonnnn. But honestly, it's still just what Stocker said. Good mod, though, since it's basically free.
Old May 16, 2016 | 02:34 PM
Drifterz73's Avatar
Vehicle: 01 tiburon
Originally Posted by Hyunshark21
Finally got some pics, because i mean you all seem so interested.......
but heres my best explanation for the DIY:
What you will need:
-12mm Socket
-5/16 Brass fitting ( or w/e else will fit over the peg)
-about 15min-1hr depending how fast you are
I believe you can do this mod without having to take off bolts 4 and 5, i did because i wanted to remove the whole part. Now as you can see in the pic i lost some of the bushings or w/e so it doesnt bolt down right, ill have to fix that tomorrow.
So remove bolts 1 and 2 (2 is hidden behind shifting mechanism)
Slip the fitting over the peg ( number 3 in pic)
Reassemble.
You should notice tighter shifter, or at least i did.
I dont have any pics of the actual fitting, i didnt take pictures during the process.
Some more pictures of it installed:
Let me know what you guys think!
Any chance of reposting pics
Old May 16, 2016 | 03:27 PM
2000J25SP's Avatar
Vehicle: 2000 Hyundai Elantra GLS
NOT my work.
I think I found these on hyundaicoupeclub.co.uk/ or one of the other UK based Hyundai forums.
It's also noteworthy that this mod can be done to Beta 1 and Beta 2 transmissions. I've done it on both style linkages.
