.25 Cent Mod Diy Soon
Old Jun 10, 2010 | 11:34 PM
Hyunshark21's Avatar
The other day i upgraded my shifting with a 5/16 brass fitting from Home Central.
After looking at this thread:
[link removed]
I noticed that mine was different from this one, there is a spring instead of a bushing.
I still pulled off the part and took it down to home central to find something to fit over the rod where the pipe fitting was put on in the original DIY.
After doing this i noticed that the shifting was less sloppy, and even a little quicker.
I will post pictures and a DIY write up tomorrow if i can do it before work.
Old Jun 12, 2010 | 10:16 PM
Finally got some pics, because i mean you all seem so interested.......
but heres my best explanation for the DIY:
What you will need:
-12mm Socket
-5/16 Brass fitting ( or w/e else will fit over the peg)
-about 15min-1hr depending how fast you are
I believe you can do this mod without having to take off bolts 4 and 5, i did because i wanted to remove the whole part. Now as you can see in the pic i lost some of the bushings or w/e so it doesnt bolt down right, ill have to fix that tomorrow.
So remove bolts 1 and 2 (2 is hidden behind shifting mechanism)
Slip the fitting over the peg ( number 3 in pic)
Reassemble.
You should notice tighter shifter, or at least i did.
I dont have any pics of the actual fitting, i didnt take pictures during the process.
Some more pictures of it installed:
Let me know what you guys think!
Old Jun 13, 2010 | 01:37 PM
. . . aside from "you need to detail that engine bay" you mean? wink1.gif Thanks for the additional photos. It helps clarify what is happening. This reminds me of a mod at the shifter-end of the assembly that I'll have to get around to taking photos of sometimes.
I wonder if this and the mod you linked in the OP should be merged into one post?
Old Jun 13, 2010 | 02:17 PM
haha im suprised with how many people arent interested in this mod, it literally cost me .25 cents for the fitting and it tightened up shifting a little more. And im interested in the mod that you did!
Old Jun 13, 2010 | 02:58 PM
It gets rid of the slop in the actual shifter mechanism itself. It makes a difference in shiftER feel, not shiftING feel so much. It makes it seem like (let's be honest here) a less-inexpensive car.
Old Jun 13, 2010 | 03:17 PM
id still be interested in seeing it, let me know when you have pics
Old Jun 13, 2010 | 09:14 PM
New thread coming shortly. Moving this thread to DIY section.
Old Jun 27, 2014 | 11:32 PM
bigfishmoney's Avatar
how do i replace that spring?
Old Jul 4, 2014 | 12:07 AM
Can the plastic clip be removed from the bushing #3 in photos?
I have a plastic clip that the #3 bushing peg fits into. Can this clip be thrown away?
Old Jul 4, 2014 | 12:53 AM
Bump
