Running Ubuntu on Android
Old Feb 10, 2011 | 07:55 AM
Default Running Ubuntu on Android
I was going to make this into a blog post, but it wil require updates and the blog system blanks out posts after a few updates.
I. How android works
So lets start by looking at how android works.
1. boot sector
When you turn the phone on, you see the AT&T or whatever logo. This is the boot sector. It is setting up the phone to perform the next action
2. boot loader
The boot loader is responsible for many things.
  • Recovery mode - this allows for reflashing and updating of software under normal conditions
  • Download mode - this is a failsafe method of updating and flashing software
  • Boot linux/Android -this is the normal mode of operations
3. Linux layer
The Linux layer provides the framework for Android to operate... Disk access, memory management, permissions management, device interfaces, process management...... My own phone runs Linux kernel version 2.6.32.9 currently. The Linux layer is extremely scaled back from what I'm used to. The main difference is the lack of tools and home folder. Many of the files you'd expect to see on Linux are missing such as /etc/profile, passwd, group, and several others.
The reason for the lack of many Linux tools/structures, is Android does not use many of the Linux tools or the Linux permissions model. The Android os talks to the Linux layer and assigns permissions to applications rather then users. Each application runs as it's own username and it's permissions are assigned by the developer and authorized by the user upon installation on the phone. So basically, instead of the standard login/execute with user permissions model, the application is assigned permissions by the user and the user is assigned to the application.
4. The Android layer
Android uese the "Dalvik Virtual Machine". The DalvikVM is much like the JavaVM. The DalvikVM allows each application to run in it's own Virtual Machine. By running in a VM, each application can be started and shut down nearly immediately by saving the state of the memory and reloading it on demand. Each DalvikVM application runs similarly to a standard computer on a network and communicates with the main system and other applications in a limited way. This allows each application to run in a "Sandbox".
II. What is required to run Ubuntu
Ubuntu Linux requires
1. Linux layer -present
2. Memory space - present
3. X interface reader - handled by Android VNC application
4. A new root folder -needed
5. An Arm Ubuntu Filesystem -needed
6. X interface - needed
Currently, I'm working on creating a 4gigabyte armv7l compatable image of Ubuntu in a virtual machine on my Desktop computer (which also runs Ubuntu). I'm running into difficulties with the keyboard. The Keyboard keys ASDF translate to ABCD inside the virtual machine.
Continued later....
Old Feb 10, 2011 | 12:18 PM
Interesting project.
Old Feb 13, 2011 | 12:07 AM
Well, I was able to get it working tonight.... I'm running Lubuntu. At first I was a bit dismayed that I could not get full-blown Ubuntu running because of a package called Mono which Microsoft cleverly placed into the Linux upstream... Oh well. Lubuntu works and it's designed to be lightweight so my Android's processor does not get overtaxed.
The key to the keyboard issue is that Canonical makes rootstock. They set their default keyboard setups to PC105. Here in the USA, we use PC104. So... The completed image creation goes like this..
Code:
sudo rootstock --dist lucid --seed lxde,tightvncserver,openoffice.org,gimp,ssh -fqdn localhost --login ubuntu --password ubuntu --imagesize 3800M --notarball --fullname "Ubuntu for Android" --kbmodel pc104  --locale en_US.UTF-8 --serial ttyS0  --doswap --swapsize 256M
Let me break this down a bit...
sudo rootstock
rootstock creates a ARM image file in a QEMU virtual environment. It then takes that image and turns it into a usable virtual hard disk when complete (if the --notarball is specified)
--dist Lucid
This specifies the distribution time period to use.. like Windows XP, Vista, and 7... Lucid Lynx, 10.04LTS is a LongTermSupport distribution of Ubuntu. It will have less features but be more stable
This specifies the packages we want to spawn into the distribution
-fqdn localhost
we will call our new ubuntu "localhost"
very high security login and password
--imagesize 3800M
The size of the image cannot exceed 3999M when placed on any VFAT drive. FAT32 filesystem is used on Android's SDCard
This is the name of the person who logs into the Ubuntu desktop. It's used for auto-fill purposes sometimes.
--kbmodel pc104
kbdmodel specifies the type of keyboard to use. pc104 in USA, pc105 in europe.
local refers to a filel on the hard disk which contains locality information like currency, time formats, and date formats.
--serial ttyS0
Serial allows a port in and out of the machine. If, perchance I find a serial port on my android, it would be nice to use it to communicate with the device.
doswap creates a swapfile. swapsize specifies what the size will be. Linux SWAP filesystems are used to store data temporarily... outputs and inputs, they also provide a place on the filesystem to place devices like serial ports and sound devices.
So... Now, I'm troubleshooting miscellanious problems to bring Lubuntu up to specs. Currently I cannot spawn a terminal inside the X interface, nor can I bring up certain applications which require the terminal. The terminal simply brings up a black screen. The terminal is very important for technical operations in Linux. I must have my terminal.
Old Feb 13, 2011 | 10:52 AM
Awesome. Yeah, without the terminal you're sort of crippled in Linux.
Old Feb 13, 2011 | 12:41 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
Interesting, because I really dont like android.. lol
Old Feb 13, 2011 | 02:00 PM
The idea is to have Ubuntu running side-by-side on Android. Using my Android's resources to tgeir fullest potential.... All the power of a desktop in my pocket and still be able to take phone calls.
Old Feb 14, 2011 | 04:50 PM
I've created a google code repository here: https://code.google.com/p/andbuntu/
It's not much yet, but this will mount an EXT4 loop filesystem (ubuntu.img file) as an EXT4. This has never been done before on android. EXT4 is used from Ubuntu 9.04 on. I believe it was made default in 9.10. This project makes it possible to run 2009+ versions of Ubuntu on Android 2.2 Operating system.
Here is the script which does the meat of the work. https://code.google.com/p/andbuntu/s...se/trunk/uboot
Old Feb 16, 2011 | 01:53 PM
I have terminal up and running inside X. Somehow during the creation process the /dev/ptmx device was destroyed and replaced with a file called /dev/ptmx. Just a simple, blank file.
to get terminal running, the commands were simple
Code:
rm /dev/ptmx
mknod --mode 666 /dev/ptmx c 5 2
Now I'm focusing on the memory issues. Android reports about 17 megs of memory available. However, I believe I can get it running by utilizing the linux swap inside the virtual filesystem.
