C programming help
Old Dec 7, 2010 | 07:58 AM
AtomicX's Avatar
Default C programming help
Hey guys I need to make a program that lists out prime numbers until it is interrupted with the
Control-C interrupt signal. I need to use fork()to create multiple processes, each of which has the job
of testing one prime. The main program collects the exit status of each child process and uses that to
figure out if the number should be outputted to the screen. The output must be formatted to 8 primes per
line, and continue until the main program is interrupted. The output will look like this:
Can anyone write this?
Old Dec 7, 2010 | 08:06 AM
You mean do your homework for you? :paranoid: I hope you aren't planning to write our next encryption algorithm
Old Dec 7, 2010 | 08:07 AM
AtomicX's Avatar
Its my last one, and I cant figure it out
Old Dec 7, 2010 | 08:47 AM
I'm just giving you a hard time. I'd help if I could.
Seems like a fairly popular project. I'm sure Google could help in some way ??
Old Dec 7, 2010 | 08:55 AM
AtomicX's Avatar
I tried I can't find anything =[ I really need help
Old Dec 7, 2010 | 10:00 AM
AtomicX's Avatar
I'm willing to pay $50 to whoever can solve this for me, I can Include more instructions through PM
Old Dec 7, 2010 | 11:16 AM
This is a rediculous question and you should drop the class if you cannot figure it out. You asked a question before on C programming help which I requested to know more and you did not answer.
Ok, so for the help portion of this... I don't do C, but I can pseudocode some stuff for you.
Code:
#a prime is a number which cannot be divided by any number except 1 and itself.
integer testprime(int Number) {
#make a counter to check.
 int ReverseCounter=Number
 Double result=0
 #loop through all numbers less then the Number to check and greater then 0
 while ( ReverseCounter > 1 ){
  ((--ReverseCounter))
  result=Number/ReverseCounter
  if ( ((int)Result)-Result == 0) {
   #if the result, casted as an integer, is a whole number, then return with status 1
   return 1
 #if we made it through the loop without returning a whole number, then return 0
 return 0
void Main() {
 int Number=0
 #loop through all numbers, fork processes.
 while (true) {
 #I don't know the syntax of the fork() command, but fork the process here
 #Test the output status
 #if the output status is 0 print, else don't print
Note, this will get you as high as the Double value can test.. that is the limitation.
Old Dec 7, 2010 | 12:49 PM
I'm afraid that unless he KNOWS C, he won't be able to transfer that and compile it
I spent three semesters programming Java, and while I understand the language enough to read it, I couldn't write anything today (4 years later)
Old Dec 7, 2010 | 02:24 PM
Java and c share very similar syntax. To make this work in c, it's a matter of changing a few symbols to c language.
When I program, I have google on one monitor looking up examples and syntax while I do the actual programming and debugging on the other.
For this example, you take the code above and debug it until it matches C syntax with no errors and compiles properly.Programming is not easy and even the best programmers need a reference when dealing with new commands.
Besides. I used as much c syntax as I could so some lines are syntactically correct..
