Cooking oil/pan/element question
Old Apr 17, 2013 | 01:21 PM
bluegenesis's Avatar
Vehicle: 2011 3.8 Genesis
Default Cooking oil/pan/element question
When I use my cast iron pan over medium heat and put some oil in it, the oil all falls to one side of the pan and parts of meat that I cook arent sizzling.
Is it normal for liquids to fall to the left side of the pan and is it ok that some of the food that Im cooking isnt sizzling?
There was an appliance repair person at my building that worked on the stove today but didnt want to change the elements/burners that seem to be unlevel.
It seems level with water but with more slippery things like oil it all falls to one side of the pan.
Old Apr 17, 2013 | 01:27 PM
wheel_of_steel's Avatar
Old Apr 17, 2013 | 10:49 PM
Fill pan so half the bottom is covered with water
Shim bottom of stove as required until whole bottom of pan is covered with water
There may (should) be adjustable feet for this purpose
Old Apr 18, 2013 | 07:35 AM
bdiggy's Avatar
If you coat the bottom by swirling the oil right before you place the protein in the pan, you will have oil coating the entire piece. Just tilt it once in a while to bring the oil back to the drier side to recoat it once in a while. How old is the pan? Are you sure the pan isn't slightly warped?
