My Car Wants To Be A Bastard Problem Child
Old Feb 4, 2009 | 10:00 AM
demon_fox's Avatar
Vehicle: 2000 hyundai tiburon
ok well for the last 2 weeks i have been experiencing trouble with the tib. its missing on all four cylinders, ive checked the coil, gave it a tune up in august, i cahnged the timing belt 4,000 miles ago, changed the crank sensor, and the tps. as far as i know the only things left are the knock sensor and the cam sesnor. but idk im pissed beyond all reconition at the tib because ive n ow had to turn my truck into a dd. im buhying both sensors off the blue parts tib in new york. idk if these dont fix it imma blow it up or drive it off a cliff
all opinions aree needed
Old Feb 4, 2009 | 11:12 AM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
Old Feb 4, 2009 | 11:38 AM
Why not post a clear thread about what's wrong with it in the appropriate area so we can try to help out?
Old Feb 4, 2009 | 12:35 PM
Tibbi's Avatar
Maybe's he's just venting in here and not actually looking for constructive help.
The grammar and punctuation could be a direct result.
Old Feb 4, 2009 | 01:36 PM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
DW, have you tried changing your spark plugs and/or wires? how about the coil?
Old Feb 4, 2009 | 01:38 PM
ZKend's Avatar
it says hes done a tune up and checked the coil...but last august is a while but should not be the result
Old Feb 4, 2009 | 01:42 PM
For some folks, an oil change is a tune up, so I'm not sure what he actually has done so far. I want to help, but I just keep catching snippets in the shoutbox.
Make up a thread, with some detailed listing of what's up and what's been done DW.
Old Feb 4, 2009 | 01:51 PM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
Check to see if you are getting a good 12v to the injectors and try to swap them out. I had a misfire on my elantra that turned out to be an injector not working properly.
