I Have An Rd2 Exhaust Manifold With A Rd1 Catback
I've heard you can stab them with a long screw driver until the fux0r breaks apart inside.... does that work until i get a header? Or will that not be possible with this vehical?
^^punching out a cat, yes you can do it but the better option would be to just wait! lol. Patience.
PLus you are going to need more than a long screwdriver lol. More like a heavy ass iron/steel pole with a pointed tip and slam it down inside the cat multiple times. You'd be surprised how much platinum and honey comb pieces fall out.
WORD OF ADVICE! Do not breath the very very fine dust that will accumlate around where you are working. Do this away from people and outdoors. Dispose of pile of platinum carefully, Don't just throw it in a trach can and watch the plume of ash/smoke rise.
Or like i said first, just friggin wait mang.
<div class='quotetop'>QUOTE (Sparticus @ Dec 11 2005, 02:08 PM) <{POST_SNAPBACK}></div><div class='quotemain'>if i'm not mistaken.... all US (probably N. America) Tiburons have 2 catalytic converters...</div>
NO
late 98's-00's have ONE Cat, right after the exhaust manifold (outside cali) ONE PIECE MANIFOLD AND CAT
All 01's had "cali emmisions", in Canada and US, and have TWO Cats, One after the exhast manifold, ONE PIECE and one after the flex.
97's(96 in Korea) and Early 98's had a non "semi-header" exhaust manfold (looks kinda like the 1 piece) and a separate cat. right after.
<div class='quotetop'>QUOTE (hamhead @ Dec 11 2005, 02:17 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I believe it was only some 1.8L that came with the "semi-header" as you people call it. I've never seen a 2.0L with it.</div>
That is absolutley correct.
<div class='quotetop'>QUOTE (hamhead @ Dec 11 2005, 02:17 PM) <{POST_SNAPBACK}></div><div class='quotemain'>All U.S spec 2.0L Tibs I've seen have 2 cats... and most other cars have two cats as well...</div>
NO, Look at above
NO
NO, Look at above
<div class='quotetop'>QUOTE (hamhead @ Dec 11 2005, 10:17 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I believe it was only some 1.8L that came with the "semi-header" as you people call it. I've never seen a 2.0L with it.</div>
Mine 1997 year 2.0 KDM Tib has only 1 cat under the car (after flex pipe).
