Heat Shield Cleaning
Vehicle: 2006 Pontiac GTO
Hi everyone!
I'm trying to clean up my engine bay a little and I removed the heat shield to clean it properly. It is sprayed with a lot of dirt, but I am having trouble removing it (probably because of the high temperatures and because nobody cleaned it in 5 years..). I tried an engine cleaner product (black magic engine shine 2-in-1), aircraft remover, even battery terminal cleaner smile.gif) but it doesn't seem to come off. I used a toothbrush on a small area and brushed with engine cleaner for 5 minutes on a small area and it barely seems cleaner than the rest. Any ideas on what I can use? What's the most heavy duty thing you can use to clean metal? Thanks!
mediablasting is the only quick/easy/cheap way to get metal like that perfectly clean again.
Otherwise just clean the contaminates off of it the best you can and rattle can it...
<div class='quotetop'>QUOTE (StrikeEagle @ Mar 24 2007, 11:07 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Aircraft remover????? Oh dear.... 02.gif</div>
Thought it wouldn't hurt to try smile.gif What's the problem? (I'm a noob hehe)
Don't mean to hijack the thread but I have been wanting to clean my shield but have found it almost impossible to remove. Is there a good way to go about removing it with like WD-40 or something in that area?
For me, the right screw was easy and the one in the center was missing smile.gif. But the one on the left I couldn't get it to open and it didn't seem very safe to force it. I used some Liquid Wrench on it (add a few drops, tap a little with a hammer, repeat 3-4 times) and I left it like 20 minutes and then it came off.
