Will 2000 Tib springs fit a 2003 Tib???
Old Nov 22, 2002 | 01:55 PM
G SHARK's Avatar
Default Will 2000 Tib springs fit a 2003 Tib???
I got an extra set of B&G springs just sitting around and my bro wants to put them in his 2003 tibby. Will it fit ???????
Old Nov 23, 2002 | 01:27 AM
They will probably fit, but the 2003 is 400lbs heavier than the gen1 and gen2. I doubt it would give a good ride.
Old Nov 23, 2002 | 06:34 AM
G SHARK's Avatar
Old Nov 23, 2002 | 11:39 AM
Jmontigny's Avatar
Vehicle: 02 Elantra
The 03 Tib has a tapered rear spring which means the bottom is a larger diameter than the top. The oder Tib has a the same diameter top and bottom. Also on the front there is a different upper mount design. The 03 Tib even uses a different front upper mount than the 01-03 Elantra. And finally, like Random said, the new car is so much heavier than the old one that I would stick with ones designed for it.
