will 14" fit my car???
Old Nov 7, 2001 | 01:49 AM
Tuscani Elisa V6's Avatar
Default will 14" fit my car???
it's from accent GT. I know it has same bolt patter but what i'm worried about is the OFFSET and the clearance of the brake caliper
Have Hyundai changed the size on the rotors since 97? if not, then I wouldn't have problem but if they enlarged it, then I might have problem
Old Nov 7, 2001 | 02:56 AM
My question is...why do you want to go with a smaller rim??? If you do, then you'll need a 65 series tire so that it stays within the factory diameter.
Old Nov 7, 2001 | 03:28 AM
skierd's Avatar
Vehicle: 1997 accent L
Jin, why would you even consider accent wheels?
1) Your calipers will most likely NOT fit unless you goto accent brakes.
2) The accent wheels aren't wide enough to hold a tire with enouh extra rubber to get u down the track faster. No reason to do this.
BTW, don't u have 17's already?
Old Nov 7, 2001 | 07:16 PM
Look for a set of stock tiburon 14" steelies. They will accept wider rubber than the accent rims and you will have no problems with brake clearance.
Old Nov 8, 2001 | 02:55 AM
*hehehehehe* Steelies! tongue.gif Then you can get some really cool looking chrome hubcaps, with the fake cross drilled rotors behind them! rolleyes.gif You'll be stylin yo, and all the Honda boys will be jealous of your phat ride!!!
