Re: NEED FOR SPEED UNDERGROUND 2
I have had 215/40/17 tires with a +42 offset rim for a couple of years now. There is TONS of room in the back but the front is a different story. I have barely touched the front fenderwell at the top a couple of times other than that no probs. Some minor fender rolling fixes that easily. I am also lowered about 1.5" with Eibach springs.
Re: Widest tire for our cars?
<div class='quotetop'>QUOTE (Cuda-Turbo)</div><div class='quotemain'>I have had 215/40/17 tires with a +42 offset rim for a couple of years now. There is TONS of room in the back but the front is a different story. I have barely touched the front fenderwell at the top a couple of times other than that no probs. Some minor fender rolling fixes that easily. I am also lowered about 1.5" with Eibach springs.</div>
so basically 225/40/17 should be just fine smile.gif thanks to another person for their input smile.gif |
Re: FS : lots of goodies UPDATED 10/10
ive got 205/40/17 on my front and 215's in the rear. when i first got the 215's they were on the front for about a week then i moved em to the rear cuz i get fender rubbing. so im gonna leave them back there and one day drop to 16's .... ive also got the b+g springs, which is around a 2" drop
Re: tibs in nopi
I don't want 17s, so I should be fine I hope
Re: Glad I dindnt have the car painted
<div class='quotetop'>QUOTE (OdessitPashka)</div><div class='quotemain'>so basically 225/40/17 should be just fine smile.gif</div>
No But sure, go try it,... :roll: Not my tib,... |
Re: Type R Wing Group Buy *CLOSED*
<div class='quotetop'>QUOTE (KayJai)</div><div class='quotemain'><div class='quotetop'>QUOTE (OdessitPashka)</div><div class='quotemain'>
so basically 225/40/17 should be just fine smile.gif</div> No But sure, go try it,... :roll: Not my tib,...</div> sorry, i meant to say 225/40/16 |
I think if you are at stock ride height you SHOULD be able to roll with 225/40/16 with some fender rolling. That size of tire is actually .3 inches smaller in diameter than stock which will give a little more clearance. Let us know how it works for ya!! smile.gif
Re: MUST SELL! misc. items left
When you go with the 225, go to the track and let us know if there were any differences in your times.
Re: DIY for a starter button install?
<div class='quotetop'>QUOTE (CyberShark)</div><div class='quotemain'>When you go with the 225, go to the track and let us know if there were any differences in your times.</div>
it should definitely make some difference! First couple of time i went to the track with 195s and kept getting 16s, but once I got 205s and alignment i was able to improve my 60' time and my 1/4 mi time. |
Re: Fuel Injector Question
OdessitPashka, if you're really set on 225s, I recommend you just get the front pair and try it out for a week, if you find that there's no problems then buy the other two. If however you do find you're rubbing then just move them to the back and get a smaller size for the fronts.
Personally I'm rolling on 205/40/17 with the eibach spring. I find that I'm rubbing a bit when the road isn't perfectly flat and my wheel is turned full lock. |
