Whiteline sway bars
Old Feb 10, 2010 | 09:07 AM
tiburon423's Avatar
Vehicle: 2001 Tiburon
Thumbs up Whiteline sway bars
I know a few of you have the sway bars for the Tiburon - but do they make that much difference?
They look to be a similar shape to the stock ones
I already have front and rear strut bars. would the anti-sway bars stiffen things up more than now?
And has anyone experienced any problems after installing them, like with loosing the back end on fast cornering?
Plus, which bars would I need? There seems to be different thicknesses and adjustable/non adjustable.
Thanks
Old Feb 10, 2010 | 09:09 AM
ereeves116's Avatar
Vehicle: 2002 Accent
If you can I would advise getting an adjustable one just for the flexibility you'll have in settings. In the snow, if i have my backend too stiff, it'll slip out all the time. but that's kind of half the fun.
Old Feb 10, 2010 | 09:18 AM
I have both front and rear swaybars and I love them. The front one is 24mm thick compared to the stock 18mm one. The rear one is only 1mm thicker then stock but it does make a difference. I've had no problems with mine and would recommend them to anyone who was looking for better handling out of there Tibby. smile.gif
Old Feb 10, 2010 | 10:14 AM
JonGTR's Avatar
I have the rear adjustable. It made the back end slide out more. Could definately tell the difference. You'll want both.
Old Feb 10, 2010 | 10:40 AM
Front and rear strut bars + front and rear sway bars + Eibach springs + KYB Struts = Twisty Road Orgasm
Old Feb 10, 2010 | 06:39 PM
Front and rear strut bars + front and rear sway bars + Eibach springs + KYB Struts+Adjustable endlinks+Yaya Bushings+Ape Traction Bars = Twisty Road Orgasm
Old Feb 11, 2010 | 06:59 AM
I want to get a set of Ape traction bars really bad. Where did you order yours from?
Old Feb 11, 2010 | 07:29 AM
JonGTR's Avatar
I had them when I was in the group buy. Waited like a year for them, but then sold them cause I wasn't going to mod the Tib for a long while. It also hit my IC pipe on the passenger side.
It's a very simple system that could be built yourself. That's why I didn't mind selling it.
Old Feb 11, 2010 | 10:37 AM
QUOTE (Visionz @ Feb 11 2010, 08:59 AM)
got mine from a member on RDT, that got it from Javageek when he got rid of his tib
