wheel spacer
Old May 31, 2004 | 06:05 PM
01roller's Avatar
has any1 considered wheels spacers for a lower offset? im thinkin about it right now, but i would like some info from others before i decide... thanx
Old May 31, 2004 | 06:09 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
Default wheel spacer
i have never done it, nor have i heard of people doing it. but some things that you have to keep in considering are the following: (quoted from KSpec)
It offers more of negative offsets depending which ones (size of spacer) you choose from.
By having an offset of 40mm wheels and installing 15mm spacers will be like having 25mm wheels.
Customers have to know what offset their rims are.
Also the ride height, clearance between the fenders and tires, and size of wheels/tires are needed
to be checked out before hand.
Wider wheel base should provide better cornering performance.
thats all i can offer you...but this is a start to get more input from other members.
Old May 31, 2004 | 06:16 PM
canadianshark74's Avatar
you might want to invest in longer wheel bolts aswell.
from what I have read on different boards, wheel spacers were not recommended.
our wheel bearings are bad enough in our cars, putting the wheel 15mm farther from the hub, in my opinion is not a great idea.
Old May 31, 2004 | 06:30 PM
01roller's Avatar
the spacer im eyein is the eibach pro spacer... it comes with longer studs .... it doesnt sound to bad to me ....
Old May 31, 2004 | 07:38 PM
another problem people do not tell you about spacers.. in a powerful and semi-powerful front driver (like the tib) unless you are pointed straight and the road is smooth.. you are going to get all sorts of torque steer under acceleration. Most front drivers are set up for a certain amount of offset.. the further out you space the wheels.. the more leverage the wheels have over the steering.
Old May 31, 2004 | 11:30 PM
Uhm, guys, the Jspeed sets sold on KSPEC.COM are MADE for these cars and come WITH the new studs.
Old Jun 1, 2004 | 02:08 AM
yellowcoupe's Avatar
i Have the nice Jspeed ones on my rear wheels.
Installed them last week!
15mm on each
still assessing them but i like them very much right now.
Generally suggest not putting them on the front wheels as the geometry changes and handling may be compromised
Old Jun 1, 2004 | 11:51 AM
01roller's Avatar
yellowcoupe what size rims, tires and drop you got on your ride? i might get the spacers for my rear only cuz the body is wider than the track, do the spacers put your wheels about flush with the fenders? thanx
Old Jun 10, 2004 | 12:15 AM
Cuda-Turbo's Avatar
I have the H&R 25mm spacers on my rear wheel hubs and have been there for about a year now. They aren't cheap ones and are hubcentric. I have the Eibach Pro-Kit drop (1.2") My rims are 17" with a +42 offset with 215/40/17 Kuhmo 712s. I have had to do some fender lip modification for the tires to clear. (grinding LOL) But with my Cuda kit I wanted to bring the rear tires as flush as possible due to the flaring of the kit at the rear. Looks hella better than stock! laugh.gif
Old Jun 10, 2004 | 12:18 AM
2bits's Avatar
I was going to do it, my 97 has problems with fitting rims but with a spacer i can jsut fit. But the problem is, it puts more stress on your bolts, long bolts you can do. but it costs money, basicly, i just stayed away from the whole deal...
