Whats the widest tires you can put on a tib at stock height?
Vehicle: 2000 Tib
How wide of a tire can you put on a tib without rubbing if its not lowered any and still on stock 15" rims? Will 225's work or can I go wider?
Vehicle: 13 Gen Coupe Ult.
I run daily a 225, and i have a set of 245 radials for track use, and i get no rub when i turn but they are past the fender, so if you streeted them i guarantee thry would chewed up fast. but you I am running 225 tucked with a 2" Drop now and i do get a little rub if i turn it to the lock and hit a dip at the same time, but it will turn lock to lock and not rub if you are on a smoother surface!!!!
Ron he said stock wheels no way you are running 245 s on stock wheels
225/50r15s here but I mounted em myself each tire took me roughly 25 minutes so whoever mounts em will effing hate youit fit but tight I'm gonna phone book flare the renders and mine is a j2 not a rd and its lowered on eibachs
