Whats the lowest drop spring you can get for a tib?
Old Oct 18, 2010 | 08:49 AM
tibby98's Avatar
Vehicle: 98 Tibby
Default Whats the lowest drop spring you can get for a tib?
Are the B&G springs (2" drop) the lowest you can go with a static drop? I know theres the crappy coil over sleeves but I heard alot of bad things about them. Actual race coil overs would probably be my best bet if I wanted to go lower than 2" correct?
Old Oct 18, 2010 | 09:06 AM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Crappy Ebay Coil -Over Sleeves = Race Coil Overs!
If you want a Cheap race coil over just take the springs off the damper and then simply re-install dampers!!!
You will have the same ride quality!
If you wanna go springs B&G's are okay
If you want to go low get D2 coilovers or Ksport, I know people talk sh*t about Ksport, but most of the nay sayers havent had them. I have a set of Ksport Pro's not the Ebay special and there amazing, there adjustable as a tein and ride nicer when setup RIGHT, I installed mine, not hard at all, Then i took it to a shop and had them balanced! The dampers done work as good as i like for adjustable factors, as it maybe 32 way adjustable but you can really only use 12, as 12 is just about as stiff as you will ever need!!!!
Old Oct 18, 2010 | 09:48 AM
Bommello's Avatar
I believe the h&r springs are the lowest as far as springs go
Old Oct 18, 2010 | 10:29 AM
H&R's are what i had, along time ago, In my opinion they blow, there super soft, like a Cadillac, when you turn your car rolls like a bus!!!
