What causes bulges in tire sidewalls
Old Oct 12, 2010 | 01:03 PM
bxtib's Avatar
Vehicle: 01 tib
Default What causes bulges in tire sidewalls
Both of my front tires developed bulges in the sidewalls. I replaced them, but I was wondering what causes it? These were Nitto NeoGen tires, so they werent cheap crappy tires. Do potholes do it, or is it something else like over inflating?
They looked like this
Old Oct 12, 2010 | 03:38 PM
you hitting sh*t causes that
its a weakness in the sidewall, air is pushing past the plys
Old Oct 12, 2010 | 08:00 PM
Also when the tire was made on a Monday or Friday. If two tires from the same lot had it happen near the same time, that's a warranty claim right there.
Old Oct 12, 2010 | 11:43 PM
krazytib's Avatar
I had a set of Kuhmo Ecsta tires on my car that had sidewall bulging issues from hitting potholes.
I now run BF Goodrich g-force Supersport A/S ZR rated tires which have way stronger sidewalls but they do cost a little more per tire.
Old Oct 12, 2010 | 11:53 PM
UrS0NvS's Avatar
don't hit potholes, simple as that.
Old Oct 13, 2010 | 01:19 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
A busted belt causes it and it's usually caused by sharp impacts.
Old Oct 14, 2010 | 03:36 AM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
The plies in the carcass have separated, and that area is going to be the point at which the carcass terminally fails. As has been said, impact to the sidewall OR not enough air in the tyre leading to the sidewall folding, and running up against the rim. If it isn't these, then either over-inflation or a bad batch of tyres.
Old Oct 14, 2010 | 07:54 AM
BetaRD2's Avatar
Vehicle: Tiburon 2001
i had kumho ecsta and my right front developed a bulge when i hit a pothole going like 35mph, avoid potholes and you'll be fine
