Warped Rotor Question And E-brake Question
Old Aug 2, 2006 | 07:40 PM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
Will a warped rotor make a scraping sound against the brake pads when moving? I replaced the front pads to see if that was the problem and i still get a what sounds like scrapeing. last, if i replaced the rear brake pads shouldnt my pull of my e-brake be very little, i was able to crank that sucker down quite a bit (over 10 clicks my estamate). Should that not be very tight now?
Old Aug 2, 2006 | 07:42 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
generally a warped rotor will cause a pulsation while braking. not sure about a clicking.
and i dunno about the ebrake question
Old Aug 3, 2006 | 06:23 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
warped rotor will do only pulsation and vibration on high speed.
scrapping may be from dust guard (metal part around rotor that's not moving) check if it's touching anything.
Old Aug 5, 2006 | 08:58 PM
Bullfrog's Avatar
Rotor was warped upon inspection. replaced rotor. no scraping sound at all!!
closed.
Old Aug 5, 2006 | 11:00 PM
I once had a scraping sound when i installed the brake pad retainer shims wrong lmao.gif
Old Aug 5, 2006 | 11:08 PM
Closed?
