Those with H&R, does the rear bottom out?
Old Jan 11, 2012 | 01:23 PM
Jonny_D's Avatar
Default Those with H&R, does the rear bottom out?
The rear seems to be bottoming out quite often. Even on medium sized potholes there is bottoming out. Before the H&R/KYBs, with the stock shocks/springs it would take a very large potholes for the car to bottom out.
Anyone else have this problem?
BTW, the front never bottoms out and overall ride quality is great even on small bumps.
Old Jan 11, 2012 | 01:42 PM
H&R springs with KYB struts?
You shouldn't be bottoming out
Old Jan 22, 2012 | 08:02 PM
yellow01's Avatar
Vehicle: 01 tib t3t4
If it were my car I would trim the rubber bump stops if that is possible
Old Feb 3, 2012 | 11:01 PM
krazytib's Avatar
Which kit? I have no issues with the touring cup kit on my 01 Tiburon.
Old Feb 12, 2012 | 04:09 PM
ScoupeLS's Avatar
Vehicle: 2003 Tiburón GT
did you put the bump stop back?
my kyb/h&r setup is pretty stiff and i never bottom out. when i was installing them, even with a spring compressor i had a hard time putting the strut mount back because the spring was really hard to compress.
Old Feb 27, 2012 | 05:49 AM
mousepad's Avatar
Vehicle: 1997 hyundai coupe
i have H&R lowering springs with stick shocks and o-sulee spring cushions. i don't bottom out but it may be due to the spring cushions..
