Theres A Bird In My Brakes
so when im driving down the road i can hear a very annoying chirping sound coming from my front right tires that speeds up and slows down as i do.
also when i turn the steering wheel to the left its sounds like there is a grinding noie coming from the same tire.
Any ideas of what this could be??
cheers
cheers
Check to see if one of the pads is worn. If so, your caliper has seized. You'll need to replace the caliper, pads and possibly the rotor.
If the pads are fine, it's the wheel bearing. Easy replace as long as you're not captive like me 02.gif
does this only happen during breakfast? because it might be your eggs burning.
haha dude i was scared there was actually a bird caught in your brakes. goodness. yeah it's probably your pad or rotor. get either one replaced, preferably the pad. grinding/screeching noises are never good. i learned that the hard way.
Nope its usually around lunch time lol.
anyways anybody know how much it would cost me to get this fixed??? im a little short on cash till next week(payday) from buying to much stuff from people on here.
Have you checked for any small critters??? lol
Dude check the pads, they probably need replaced. My friends car had worn pads n it made a screeching sound. So thats mostly likely your problem. To have new ones put in is not too pricey at all. Or you can just do it yourself and itll cost even less.
