is there an easy way to take your wheel off with a body kit?
Old Mar 12, 2003 | 01:11 AM
justin's Avatar
Default is there an easy way to take your wheel off with a body kit?
i need to paint my calipers and possibly mess with some braking parts, but i havent found a jack recently that will fit under my body kit. are there jacks specially made for this? any ideas?
Old Mar 12, 2003 | 02:08 AM
batman's Avatar
Vehicle: 01 Tiburon
what i do is i drive up on a 2x4 block and then jack it up and if 1 isn't enough put 2 down just make sure the top one is shorter so it has to step up... mine looks like...
then i just screwed the top one into the bottom one so it cant move
although i'm sure u could buy a low profile jack but this is just a cheaper method i think
Old Mar 12, 2003 | 02:32 AM
justin's Avatar
ill have to use about 8 or 10 real little steps then... lol. i dont think u understand... when i only had my car lowered, i could take the cup off of the jack and it worked ok, but now that i have a kit, my car is about an inch and a half off the ground. i dont know what will fit under it. anyone know where to get a special jack?
Old Mar 12, 2003 | 05:03 AM
They do make special jacks for lowered cars, but they are hella expensive ($250+).
Drive your car up onto 2x4's. Stack 2 or 3 on top of eachother staggered into "steps" to get the lift you need to get the jack under your car. (also do 2 2x4's wide)
You can also have a friend "lift" the car by pressing on the top of the car or lifting on the fender to get an extra 1" of room to slide the jack under.
Old Mar 12, 2003 | 10:45 AM
batman's Avatar
Vehicle: 01 Tiburon
when i had the veilside kit installed i had room to put the blocks under the tires i just put it rite at the tire where it was pretty much behing the front bumper...theres room
Old Mar 13, 2003 | 10:49 AM
Viper966's Avatar
i can use my stock jack with my MPS kit... i cant use a scissor floor jack anymore so its a PITA to change tires but hey... sometimes you gotta deal with it
