Sway Bar Q
Old Jan 25, 2006 | 01:24 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
Will rear sway bar from Elantra fit in Tiburon?
Old Jan 25, 2006 | 01:28 PM
KayJai's Avatar
Techically yes,.. but why?
Old Jan 25, 2006 | 01:32 PM
Dmitry's Avatar
cause mine has wear where the bushings are. And I don't want to spend now much on aftermarket sway bars, I just want to use bar from a junk yard.
is it same diameter?
Old Jan 25, 2006 | 01:39 PM
Doohickie's Avatar
Vehicle: 2005 Hyundai Elantra GT 5-door
Much smaller diameter; that's why Elantra owners upgrade to the Tibby bars. Elantra bars are 13 or 15 mm depending on model.
The wear most likely is not the bar itself but just the bushings. Just get new bushings (and maybe new end links). That should cost less than US$50 in parts (not sure what Russia prices are like, but I can't imagine it would be that much), and except for dealing with rust is a pretty easy job.
Old Jan 25, 2006 | 03:08 PM
Dmitry's Avatar
bushings - 4-5 bucks each
links - about 15 each
When I took bushings I found out that diameter of sway bar in that place were smaller. I installed new bushings but in about 10K miles it started to click - click again...
Old Jan 25, 2006 | 07:02 PM
doohickie your talkin about the xd elantras
hes talkin about the j2 elantras
they are the same
d are you gonna want one? i need to know ASAP
Old Jan 26, 2006 | 03:19 AM
Dmitry's Avatar
if it's same diameter as I have and it fit - sure!
