Suspension Help/advice
Old Jun 15, 2006 | 09:20 PM
RedRide97's Avatar
Vehicle: 1997 Hyundai Tiburon
Ok. Im looking into purchasing an "Eibach Prokit" for my 97 Tib.
My question is if i JUST BUY the Eibach Prokit, will i need any other sort of suspension support other than just those springs? What will i need if thats the case? strut bars?
I want a nice drop for an agressive stance, improved handling, and less body roll. But, i dont want my stock
struts to crap out real quick.
This is obviously just my daily driver so no need for any higher-end coilovers or anything. I just want the previously mentioned results without spending too too much cash. So basically the safe, value concious route.
I've been told to get KYB AGX's but for almost 200 bucks per, i dont think ill go there.
What do I do?
Old Jun 15, 2006 | 11:21 PM
lilo shark's Avatar
the kyb's are only $45-51 for each. who ever told you that lied. look at nopi.com they're pretty cheap.
Old Jun 15, 2006 | 11:45 PM
the NOPI.com store also has tons of coupons and discounts. If you buy from there, let me know first and I'll get some discount codes for you
Old Jun 16, 2006 | 01:14 AM
tanc's Avatar
Vehicle: 1997 Tiburon
QUOTE (lilo shark @ Jun 16 2006, 01:21 AM)
Don't listen to him I think he's drunk.
Yes the KYB AGX will run between 150-200 per. KYB also makes GR2's which run from 45-60 per.
AGX are adjustable dampening and GR2's aren't.
Old Jun 16, 2006 | 01:41 AM
here are the part numbers you need
733020
733021
733022
733023
fronts are 169.95 each
rear are 149.95 each
there ya go took me a while to find the part numbers again those are for the agx struts
and like i said in that very same post
might as well get coilovers
Old Jun 16, 2006 | 09:03 AM
I'd skip the KYB's and get the Eibach dampner kit man, they are fantastic.
Old Jun 16, 2006 | 09:42 PM
RedRide97's Avatar
assuming the eibach prokit will only drop it 1.2", i should be ok with my stock struts though right? Just a slight decrease in my stock struts life span, yea?
Old Jun 16, 2006 | 11:31 PM
KayJai's Avatar
Why do it twice?
Just like Ron Popel says,... "Set it and Forget it"
Unless you have access to hoists and airtools, forget it, hell I have access, and I don't really want to F with it,... get it all at once and do it,... if you just want the "look" of a lower car, then stop there, with just the springs,... if you want REAL handling, save up for it if you don't have the cash,.. And DO it AT Once.
BTW, Sway bars will improve your handling THE MOST!!! Outta the springs/struts and sway bar components to your suspension,...
Trust me,... been there,...
But, if you feel like tinkering with your car, all the time, then well, do what you want.
OH yeah, be prepared to replace atleast 1 outta the 4 swaybar links when you take out your strut/swaybars, the links like to spin.....
That's all the advice I can give ya.
Old Jun 18, 2006 | 12:47 PM
lilo shark's Avatar
guess i shouldn't drink and post at the same time.
Old Jun 18, 2006 | 12:51 PM
xxxmonoxidechild's Avatar
QUOTE (tanc @ Jun 16 2006, 02:14 AM)
GR2's are also considered stock replacements. no true handling improvement.
