Suspension does't feel right
Old Sep 24, 2010 | 01:22 PM
AtomicX's Avatar
Default Suspension does't feel right
Hey I don't know if somethings wrong but for some reason if I take turns going like 40mph, I sqeel my tires.
This happens all the time and also happens if i jerk the wheel. Also when I jerk the wheel it feels almost as if im on snow or something, almost like a fishtail type thing.
I have H&R coilovers and a shark racing strut bar, anyone know if this is normal?
Old Sep 24, 2010 | 04:44 PM
...what kind of tires and how much tread left
what kind of alignment specs
Old Sep 24, 2010 | 06:07 PM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Okay, how much did you lower the thing when you got the new coilovers?
Old Sep 24, 2010 | 06:16 PM
you should get the alignment checked of course. tighten all of your strut tower bolts. bad bearing, cv joint, control arm perhaps? otherwise i've never heard of this.
Old Sep 24, 2010 | 09:28 PM
AtomicX's Avatar
QUOTE (HyundaiKitCoupe @ Sep 24 2010, 08:16 PM)
I think it might be the alignment, I haven't had one since I changed to coil-overs. And the coilovers are almost on the highest setting.
Old Sep 25, 2010 | 02:23 AM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Go lower with the Coil overs... You may have the spring tension set to soft, tighten the spring tension and set the Dampers a little harder...
Old Sep 25, 2010 | 04:06 AM
AtomicX's Avatar
QUOTE (Turboron_99 @ Sep 25 2010, 04:23 AM)
I Don't think I have this adjustment with the H&r'S
Old Sep 25, 2010 | 06:47 AM
H&R's are not fully adjustable?
Old Sep 25, 2010 | 11:14 AM
ok so.....you altered almost all of the front suspension geometry and you havent done a alignment
and yet are wondering why it wants to wander?
Old Sep 26, 2010 | 01:26 AM
I have dropped and raised mine a ton of times... Never once have i had this sensation, or have i gotten an alignment!
