Strut Bar (Front)
Old Sep 28, 2004 | 01:23 PM
UltraTibby's Avatar
Default Re: for your viewing pleasure
I know by now a decent amount of the 10 AirRam buyers have to have them installed. Has anyone found a front strut bar that will fit/work without needing to modify the shit out of the mounts?
Old Sep 28, 2004 | 01:25 PM
wattsup4800's Avatar
Default Strut Bar (Front)
im looking for one too...
quick question off topic, i understand strut bars give you more control around turns.
however, does it give you a better launch???
Old Sep 28, 2004 | 01:28 PM
UltraTibby's Avatar
Default Re: Strut Bar (Front)
I would say yes and no. If you have moded enough to have enough HP that the front end twists due to the torque then yes I would imagine so. If not then you probably wouldn't notice much of a difference on the launch.
Old Sep 28, 2004 | 01:31 PM
thats what i figured
i know ive seen someone with a strut
Old Sep 28, 2004 | 02:12 PM
LarryMcFly's Avatar
If you want something to help you lauch, put a bar between the two ends of your cassis, it's under the header usally but take a look, and you will see.
Old Sep 28, 2004 | 02:59 PM
Default Re: 10 steps to "RAM AIR" induction
isnt that where a strut bar goes???
Old Sep 28, 2004 | 03:09 PM
01roller's Avatar
Default Re: which wheels
QUOTE (wattsup4800)
did you mean sway bar
Old Sep 28, 2004 | 03:28 PM
LarryMcFly's Avatar
Default Re: Pictures of car!
Strut bar links the top of your shocks. I'm talking about the ends of the chassis. You have an oem sway bar. Aftermarket sway bars are stiffer but it's not a new element like the strut bars. But i'm not talking about sway bars either. Sway bars will limit body roll, strut bars will limit body torsion but the bar i'm talking about limits chassis "opening".
Old Sep 28, 2004 | 04:08 PM
what would you call it?
Old Sep 28, 2004 | 04:20 PM
Default Factory Sunroof
a Lower "Stress" bar.... of course I also refer to the "strut" bar as a stress bar too...
