Squeling Tires
Old Apr 11, 2005 | 09:53 PM
hamhead's Avatar
Kayjai basically has it. Definately check the tire pressure first... all these darn temperature changes make you have to adjust them regularly. I've been lazy and haven't checked mine in a while.
Of course they are more performance orientated tires so they aren't going to last as long as normal replacements. If those five months have put a lot of miles on them they may be getting worn like normal, especially if you've been having a little "fun" with them. tongue.gif
Believe it or not, the stock tires are actually rated as performance tires. I had those worn down a good bit in 7 months (7000 miles).
Old Apr 12, 2005 | 02:59 PM
00tibby's Avatar
ok, i was at 35 at each tire and one tire was at like 37, so i decreased it to 34 front, 33 rear. those numbers sound like they would be good for hard cornering?
Old Apr 12, 2005 | 03:11 PM
brian01tib's Avatar
for hard cornering you want very hard tires so they wont roll on side wall, like I run 43 in front 38 rear at track but 30 all around regularly for even tread ware
Old Apr 12, 2005 | 07:35 PM
00tibby's Avatar
ah, ok that makes sense so maybe bump it up to like 38 front 36 rear? ill try that setup tomorrow.
