Spacers... Does Thin Mean I Can't Use Duel 4 Lug Wheels?
Old Aug 1, 2008 | 01:31 AM
gsasha1's Avatar
Vehicle: tiburon 1998
I'm looking for some spacers.
Noticed the ones on Ebay, that look good, hubcentric, and resonably priced.
They mention that If you use them, you need to make sure your wheels have a recess in them (like found on 4X114.3 rims, and not dual pattern - both 4X100 and 4X114. Like the reason for getting non captive systems.)
Is that true? Or I can have them with a dual pattern wheel?
thanks!
http://cgi.ebay.com/ebaymotors/_Car-Truck-...6.c0.m245.l1318
Look inside^^
Old Aug 1, 2008 | 01:40 AM
you always gotta put wheel spacers on any aftermarket rim, and/or spacer (usually come with them already intact). i hope you have them. next, if you already have your rims on without problems, then you should be fine. they only tell you you need grooves to go over the bolts, but if you don't have captive hubs then you're ok.
Old Aug 1, 2008 | 07:36 AM
Dual = A set of 2, or doubles.
Duel = A fight using swords, guns, knives, usually between 2 people.
I'd like to see a Duel with wheels. that would be neat.
