Rubbing?
Old Feb 24, 2004 | 10:18 AM
nexuz's Avatar
Ok, chances are this is a old topic.. but i can't find any help regarding this.
my rims, upon closer inspection.. and now a very sore back.. are TSW Blades' 205/40/17 .. not, 205/45/17 as I stated before. I don't know what the problem is.. but the passenger side tire itself, on the inside is buckling/buldging at 1/4 of the sidewall. I do notice some rubbing when going into bends.. but only tight corners. would this be a cause of my problem?
I created a picture to help show you what I mean. it is NOT to scale. Will try to provide actual photos.
The area in red, is on the inside
Old Feb 24, 2004 | 12:38 PM
cdogtibby1's Avatar
how wide are the rims and tires... maybe you need a spacer or something...
Old Feb 24, 2004 | 12:43 PM
nexuz's Avatar
well, i don't know.. I mean, it is only happpening on 1 tire.. and only 1/4 of the way around it.. I thinking a belt or all(minus 1) on the side wall are gone. Cause it looks like, it is cut into the rubber.
Old Feb 24, 2004 | 03:59 PM
Voiddweller's Avatar
almost sounds like there is something wrong with the camber or tow of that tire.
Old Feb 24, 2004 | 04:14 PM
cdogtibby1's Avatar
ur speaking a whole different language to me there voiddweller... but i do kno about the belts going out on a tire... had that happen once, bout lost my tibby!
Old Feb 24, 2004 | 05:06 PM
not2happy's Avatar
Are you sure the tire is seated on the rim properly?
If it were rubbing, or out of alignment I would think it would be worn all the way around the tire.
Maybe the tire has a defect from the factory. How old are the tires?
Old Feb 26, 2004 | 07:54 AM
nexuz's Avatar
I dont know how old they are.. I bought them off my cousin who sold his tib in aug 2002. I put them on last year.. and near the end of the season(october).. they looked like that.
I am wondering it it is the seal, that could of gone, cause came out from work one morning and th tire was flat.. hmmm.. ponder.. anyone wannaa buy a tire? no.. didn't think so. well, eitheer way I wanna get somethink with a 2.63" height.. so maybe a 205/30 or 35.
well, thanks for your input. If i write back in this post it means I found out what the prob is/was
