Rim Weight question
Wheel weight also changes, depending on who sells it. For example, when I was looking into 17's, a retailer told me that Konig Heliums had a listed weight of only 15lbs. I talked to a Discount tire worker and they told me that the Heliums were closer to 17lbs. In other words, the listed weight may not be the actual weight of the wheel. 17lbs is about as lite as you will find on a wheel. Try to buy a forged wheel if you can.
Basically.. Sport Compact Car will call ANY rim light that weighs less in pounds than it is in inches diameter.. and they have a point. That does seem to be the cutting point on rims.
