Rear disc swap and alignment
Old Apr 12, 2011 | 11:41 AM
WRC_Accent's Avatar
Vehicle: 2000 Accent
Default Rear disc swap and alignment
Quick question....if I do the rear disc swap on my Accent, will it need a 4 wheel alignment after (more so for the rear end)?
Old Apr 12, 2011 | 12:16 PM
Any time you remove the strut you need an alignment. A 4 wheel alignment would be good but a single axle alignment should work for you.
Old Apr 12, 2011 | 03:04 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Shouldnt need to remove the strut for the brake job unless your doing something different. What are your rear disc plans?
