rd suspension questions
Old Feb 21, 2011 | 12:17 PM
Platinum RD2's Avatar
Default rd suspension questions
first off are the rd1 and 2 chassis and suspension the same just with a diff body?
Does anybody make rear lower tie bars for the rd 1 or 2?
im going to be dropping my rd2 1.5in in front and 1.25in in back and wondering if its going to change my camber much?
Thanks,
Chet
Old Feb 21, 2011 | 02:14 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Rd1-Rd2 Suspention is identical.
No need for lowering tie bar, Im down about 3" up front, and 2" out back for the last 3 years and zero issues.
Any time the car is lifted or droped camber will change, with 1.5" of drop you will need to find a way to adjust the camber with at the minum of 1.5 degree's + to play with.
Old Feb 21, 2011 | 02:51 PM
same chassis. some different body panels. the rear does not need camber adjustments because it is multi-link. i'm sure it will be off by a hair, but the Elantra is on B+G and the rear tires are good for at least 5 years of non-stop driving so nothing to worry about.
on a side note, a lot of the electronics and interior plastics were made a lot cheaper using more flimsy plastics than the original Hyundais.
Old Feb 23, 2011 | 10:40 AM
would all i need is some camber bolts for the front then to correct/semi correct camber?
Old Feb 23, 2011 | 10:52 AM
turbosocks's Avatar
you wont even need camber bolts, it will be off so minimal you wont notice it.
Old Feb 23, 2011 | 11:50 AM
ok thanks guys
