Other cars with rims that fit ours
Old Feb 8, 2011 | 02:04 PM
cobaltibby's Avatar
Vehicle: 2000 Cobalt Blue Tib
Default Other cars with rims that fit ours
Are there any other cars out there that you guys know of, that have the same rim pattern and offset as us? I thought I read once that certain civics have the same patterns, and their rims will fit Tiburons.
Old Feb 8, 2011 | 02:07 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Any true imported honda civic, or integra, will have a 4x114.3 or 4.5" lug pattern with a 73mm center hole for the hub. Not that i would put a honda wheel on my tiburon... but you can use that to look up other wheel brands.. but easiest to just look up by bolt pattern.
Old Feb 8, 2011 | 02:24 PM
cobaltibby's Avatar
Thanks. I would never put a stock honda rim on my car but I do see a ton of aftermarket rims on craigslist that are on civics, and are a great deal. So Im glad they share the same bolt pattern. I should be able to pick up a 2nd set of aftermarket rims pretty cheap then.
Old Feb 8, 2011 | 03:12 PM
Ebay has a fairly wide variety of 4x114.3 rims, and look for a 40 or 38mm offset. That is what our stock wheels are set at.
Old Feb 9, 2011 | 07:36 PM
Platinum RD2's Avatar
if u have an RD1 tib then ya the bolt pattern is 4x100 but an RD2 tib has a 4x114 for some stupid reason and only a real type-r integra or civic have 4x114 lug pattern most other hondas have 4x100 with the exception of the prelude, older accord late 80s to mid 90s still have 4x114. i found this out the hard way by buying a set of rims that came off of a civic so i researched it and sure enough the RD2 has 4x114. jus figured that i could pass on some of my knowledge made by mistakes lol
Old Feb 9, 2011 | 09:02 PM
WRONG
NO RD TIBURON HAS EVER HAD 4X100
Old Feb 9, 2011 | 09:11 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
Nissan Sentra Spec-V has 114x4...
Old Feb 10, 2011 | 02:17 AM
The RD1 and RD2 BOTH have 4X114.3 in metric, and in standard its 4.5".
I garuntee that!!!
Old Feb 13, 2011 | 06:02 PM
my brother had an rd1 (1999) he had a 4x100 bold pattern and i gaurentee that
Old Feb 13, 2011 | 07:29 PM
I own a 99 it has 4x114.3, I am pretty sure that they didnt make a diffrent pattern, the only diffrence is 98 old is going to have the captive setup, but still run the 4x114.3 pattern, 99 newer, non captive, still 4x114.3.
