Nitrogen
Read this crap...
http://www.livescience.com/environment/080...ogen-tires.html
So using nitrogen instead of air in your tires will increase your gas mileage by up to 10% huh? When they went outright and stated that air is made up of almost 80% nitrogen. I've talked to people who do stock car and drag racing, and the only reason they use nitrogen is because it doesn't expand when heated, thereby not changing the pressure in their tires, and not affecting the launch. But car tires are DESIGNED to accomodate for the rise in air pressure when heated, and won't cause problems if kept properly inflated. Now, their whole little blurb on how the tire will keep its pressure longer if you use nitrogen may be true, but they just can't go off claiming that by using nitrogen, it will increase your fuel mileage by up to 10%. You have to be really lazy if you can't go out to your car once a month to check your damn tire pressures. However, people are morons, and they will buy this
I didn't know blown tires explode. Oh wait, some do, but only if a MORON fills their tires with fix-a-flat, which uses a flammable propellant.
"The parallels to nitrous oxide are misleading," says Lawton. "Nitrogen does not support combustion, making it even safer than oxygen when it comes to blown tires."
I know a lot of places are starting to use nitrogen. Ive even heard of it possibly being mandated along with TPMS systems on everything. The moisture in air is effecting the sensors and throwing off pressure.
hep lexone is right ......
95% of poeple don't chek there tire pressure or don't evan know how to.... why they do it also is because as time goes by with nitrogen ou loose less presure the normal air....
It's new, but it still has not caught on and probably won't in the near future, like no2 cars. too expensive from some of the things i have heard about it and for the vast amount of gas stations NOT using it, i'll keep with air. cheack your air pressure when you fuel up, its that easy.
Its sad to look at all the cars when driving on the road that 90% of them are driving with low air pressure. I bet if everyone checked that alone there would be a big savings in fuel as well.
There are benefits to it, but i would only do it if you could get it for free or next to it as i'd rather just fill it with air and maintain the proper pressure...
for the retail side of things, Nitrogen is useless. it's basically a marketing gimmick for those tire places that DO use it. the pressure change due to heat isn't THAT bad considering automotive tires don't get nearly as hot as, say, NASCAR tires where Nitrogen makes sense. those tires are reaching crazy high temperatures.
the only thing where i can see Nitrogen being useful is that it can eliminate (or slow down) corrosion build up along the bead of the rim, which can cause slow leaks.
and since someone brought it up...... I HATE TPMS!!!!
QUOTE (Bullfrog @ Jul 14 2008, 07:21 AM)
That's exactly my point. It's like sparticus said, it's a gimmick. The story leads people to think that the reason there's so many tire issues (i.e. blowouts, premature failures) is because compressed air is causing these problems. Disregarding the fact that the actual issue is failure to perform the proper maintenance. At any rate, if you have a tire leaky enough that it bleeds down a significant amount of air in a month, then you've probably got an issue nitrogen won't fix.
