Need Help With Tire Sizes Asap
okay, the weather is getting terrible up here, and im on decent tires for summer driving. i cant afford brand new winter tires, but i found a good deal through my dads freind for some, $200 for 4 brand new blizzaks on rims, but the rims wont work on my car since they are 5 bolt. now im wondering if these will fit on my car.
i have 195/55R15's and these tires are 205/60R15's. does anyone know if these will work fine on stock ride height?
thanks in advance
Steve
thanks in advance
Steve
I don't see why that wouldn't work, it should with no problem. It'd only make them a little thicker and wider. Are you on factory suspension?
Are these good tires for winter? Make sure their tread design is made for it.
They should work with stock ride height just fine, however, your speedometer will be reading a bit lower than you are actually traveling. Reason is your new tires are going to be slightly taller than the stock size, so they will move the car farther with each revolution.
When your speedo reads 60, you will be traveling 63.2 mph.
Check this out:
http://www.miata.net/garage/tirecalc.html
Check this out:
