My Car With Eibach's.
I tore down my suspension for the 4th time already on Tue to install my Eibach's instead of Intrax. Intall went well and pretty quick. Reasons for installing Eibachs is because my 17s with 215-40 were rubbing with such low drop.
I also installed 2 sets of camber kits (front and rear) and hopefully will get an alignment done this weekend smile.gif
Here is what the car looks like with the drop. Difference on the front is not big between Eibach and Intrax, but rear is what's killing me 02.gif. With Intrax I could not stick a finger between front tire and fender and on the rear it was 1 finger. Now I have 2 fingers on the front and 3.5 on the back 02.gif
Here are the pictures of the drop at the front and rear:
FRONT
REAR
Also, here are the pictures to compare Eibach springs to Intrax:
FRONT:
REAR:
Althought I'm upset with the height of my car now, I'm very very very happy with new feeling of handling! Pot holes no longer give the effect of braking my car apart! Ride is a lot softer and smoother over Intrax.
I was also able to take some corners, and as far as I took them, feeling is almost the same. No dip, no roll!
thanks
OP
FRONT
REAR
FRONT:
REAR:
thanks
OP
Looks good mate!
It sounds like the new springs will be easier to live with on a daily basis... But you do realise they will drop a bit more over the coming months, don't you?
Where were the tyres rubbing? On the inside or on the outside?
You may have simply been able to roll the guards if it was the outside of the tire... If it was the inside, spacers may have helped a bit.
But if it was just bottoming out there's not too much you could've done about it.
I don't think it has hurt the look of your car at all though mate. Still looks sweet! B)
I was scraping my tire against fender. I had chunks of rubber hanging aroung after every sharp right/left turn I took. And yes, I tried fixing the fenders a bit, but nothing much you could do about it because tires were tucked in.
Vehicle: Elantra HD / 2007
Man, your car looks good with this springs. I like it.
If cornering is the same and ride quality is much better - then stay with this springs. Car still looks amazing.
they will def lower with time...my rear is really low, but then again it's because i have a heavy a$$ system in the trunk which lowers it alot. my front and my rear are the same and very low.
