Lowering Springs
Hey Everyone
I am in the market for purchasing lowering springs for only the front end of my car. For some reason my springs have dampened more than original probably from all the potholes from all this rain in San Diego. So when I go to make a turn they scrape my tires in the wheel well. I just got new Kumho's so I don't want to mess them up so right now I am riding with stock springs on the front and a 1.8" drop in the back. The back ones are fine so I just want to replace my front.
Does anyone know where I can buy just two front rather than in a set? Everyplace I have checked only sells them in a pack of 4.
Thanks
Thanks
Sounds like shocks to me... if you kept the stock shocks they are going to blow with a 1.8" drop eventually. Springs themselves rarely run into problems, especially since you just changed to a lowering spring not too long ago.
Better to buy a matched set anyway. Plus you know everything is new and tight. And on that note (nice segue, no?) How is the rest of your suspension? If you have tired old bushings that are getting sloppy, that can cause rubbing as well. Blown shocks would do it too.
QUOTE (hamhead @ Apr 29 2005, 01:19 AM)
I agree with Hamhead and Mad, springs rarely run into problems, AND, if your's did, buddy you DO want to change rears as well because they are probably not good quality. If the potholes were to harm suspension parts, they would hurt many other parts before they can harm a spring.
I bet it's shocks or bushings.
