lc accent upper strut mounts
Old Jul 2, 2011 | 01:18 AM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Default lc accent upper strut mounts
does anyone make front upper strut mounts that are adjustable so I can get my caster back in to spec? its not completely out of tolerance but its close.
Old Jul 2, 2011 | 09:20 AM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
I dont think I have ever seen any for the accent, but a little drimmel tool action might help
The XD has that problem so if you find a solution let me know.
Old Jul 2, 2011 | 09:26 AM
aaaaaaaaaaaaaaaaannnnnnnnnnnnnddddddddddddd
go!
http://www.ksportusa.com/asp/pillowb...roduct_id=pm01
both accent and xd are available
Old Jul 2, 2011 | 09:35 AM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
Good stuff. If I start working on the XD again I need to pick some up. I really need to do something with that thing. Either sell it to a good home or something crazy /threadjack
Edit:
Those adjust caster? I thought they helped with camber
Old Jul 2, 2011 | 10:35 AM
HotBlue02's Avatar
Thats what I read as well, camber adjustment, I thought those adjustable upper strut mounts allowed you to play with caster. Im using the 99 Elantra knuckle so caster is almost out of tolerance.
Old Jul 3, 2011 | 06:27 PM
I own those Ksports, they're camber only.
Best solution is to have the camber adjustable strut mounts and slot the holes for caster adjustment.
Old Jul 3, 2011 | 08:32 PM
Oops read caster as camber for some reason
Sorry
