just received rotors, are they supposed to be rough to the touch?
Old Jan 4, 2002 | 05:28 AM
truffryderz99va's Avatar
Default just received rotors, are they supposed to be rough to the touch?
yea yea
i kno some car parts are just rough for the hell of it, but they are really rough!
i ordered them used with about 4k miles on em, i doubt the place i ordered em from would sell me knock off rotors, so is this how the rotor supposed to feel like, and that it just needs lubricating????
thanks in advance folks!
Old Jan 4, 2002 | 05:58 AM
No, rotors should be smoother than a babies bottom.
unless they are cross drilled or slotted that is.
Used rotors? *shudder*
Braking is one of those areas where you really don't want to comprimise. I'm comprimise on power and weight before comprismising on brakes.
i would send these back and get a refund, and slap new rotors on.
www.stcharlesauto.com will give you great prices on a set of stocker rotors
www.frozenrotors.com will cryo treat them for $25 a rotor and cross drill or slot them (your choice) for another $25 a rotor.
Old Jan 4, 2002 | 08:52 AM
damn smooth as a baby bottom eh...
****, well are they supposed to smooth out when i have them mounted up or do i have to go and get them resurfaced?
damn y did i have to buy used rotors, i didnt think it was that bad of a move... sad.gif
Old Jan 4, 2002 | 09:12 AM
scotto46's Avatar
You must get them turned. Hopefully you didn't get burned and they CAN be turned.
Take em to a local shop off the car and they can do for like $20.
Old Jan 4, 2002 | 09:13 AM
damn ok, well they are definitely gonna here from me come tommorrow monring!!!!
Old Jan 4, 2002 | 12:24 PM
ok i just got off the phone wit the pep boys service department and they said they could have the rotors "turned" for 6 bucks per rotor!!
thank god, i was hoping i didnt have to send these rotors back,
thanks for all the input guys!!
Old Jan 4, 2002 | 01:59 PM
Rotors can be turned, as long as they are not too badly damaged/warped. The pep boys guys should be able to tell you if they are beyond repair.
Make sure you use new pads with new rotors or freshly turned rotors.
Old Jan 4, 2002 | 02:07 PM
y is the need for new brake pads with the new rotors???
cause i just replaced my pads about 2 months ago
Old Jan 4, 2002 | 03:03 PM
Pads bed themselves into the rotor, so they make 100% (or as close as possible) contact.
Over time, the rotors get rings around them, and the pads dig into those rings. If you put ringed pads on a flat rotor, you will only be making 25% pad/rotor contact (if that).
Spend the money, get new pads.
Some people will tell you that you can resurface your pads by smoothing them out with sandpaper. I'm not an advocate of this. For the $25 to $40 bucks a set of pads will run you...they are cheap when you consider old pads can lead to your new rotors warping, or brake fade and getting into an accident.
Like I said before. Comprimise everywhere else...but not in braking.
Old Jan 6, 2002 | 12:59 PM
erikgsi's Avatar
tucker when you showed me those rotors in florence it was from rust. usually when you buy new brake pads they will turn your rotors for free or at least thats how we do it. so how about tell them when they take your old rotors off to just use your new ones and turn them. that way you save 24 dollars and get new brake pads at the same time just an idea smile.gif
