Installed intrax today :)
wow, you live in MD too? didn't know that until now.
looks really good! i would be a little scurred because my dad's elantra is lowered and it has bottomed out a few times, especially in MD where the pot holes are like toilets!
i'd reccomend going to the healership and installing some fog lights. you'd be really surprised how much they help. they really do. they help as much as high beams do on a dark night. you can see the road a lot better. then you'll know where to dodge those toilet holes!
the rims? get some rims but get them after the winter because your tires look good now. i got mine for $800 and they lower noise level, give you better acceleration, and handling.
that RD is sweet man. also, put in some halogens like i did. i will have pics here before i go to work this evening.
nice, ... now you need new wheels and rubber!
by the way, your not using stock struts are you??
I will stock with stock rims and wider rubber smile.gif trying to keep it stock looking for now smile.gif eventually I will get a nice set of light weight rims smile.gif
no fogs for me since i need the foglight hole for some cold air for my little "air cooler" wink1.gif
I'm still using my stock struts, but not for long. I will get kyg gb or w/e they are called.
the drop is really nice and even with big potholes I havent had a problem yet smile.gif only once I took a pretty big speed bump at over 5mph and scrapped my cat or something, so if I will be careful around speed bumps I will be fine smile.gif
I also installed my clear corners, so I will take some pix tonight, it makes the car look really nice smile.gif
QUOTE (REDZMAN)
Pics are too big though. Shrink em.
Nevermind then, I converted them to links.
I added couple more pix in show room
here is the link
http://www.rdtiburon.com/index.php?name=Fo...viewtopic&t=992
here is the link
