hubcentric rings
Old Feb 11, 2010 | 09:35 AM
217Sonatta's Avatar
Vehicle: 2003 Hyundai Sonatta 2.7L
Default hubcentric rings
i got a set of rays racing wheels and im wondering, do i need hub centric rings? any of you guys put the rings on your sonata or other hyundais??
Old Feb 11, 2010 | 09:49 AM
If you dont want to constantly be replacing bearings...its good to install the rings.
Old Feb 11, 2010 | 10:08 AM
get the rings just in case the rims need it. 90% of the time they do. you want your rims to sit on the hub and not on the lugs. besides it'll help reduce steering shaking.
Old Feb 11, 2010 | 10:30 AM
I've run 6 sets of wheels on Hyundais with and without hubcentric rings and I see no difference at all. I also torque down the lugnuts in the air. Your results may vary.
Old Feb 11, 2010 | 10:46 AM
Hubcentric Rings FTMFW....
<object width="355" height="300"><param name="movie" value="http://togo.ebay.com/togo/togo.swf?2008013100" /><param name="flashvars" value="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=220543536888&query=unlocked%20iphone%203g&campid=5336025580" /><embed src="http://togo.ebay.com/togo/togo.swf?2008013100" type="application/x-shockwave-flash" width="355" height="300" flashvars="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=220543536888&query=unlocked%20iphone%203g&campid=5336025580"></embed></object>
Old Feb 11, 2010 | 07:53 PM
bdiggy's Avatar
^It makes everything easier from mounting to making sure the rim is centered before you tighten it down. For the price, they're really worth having to make everything easy.
