Help Needed...
Ok here goes, Passanger side rear, scraping noise in reverse only. sounde like metal on metal.
1) wheel bearing checked... no problem there
2) brake pads checked... no problem there
3) calipers & bracket checked... no problem there
4) rotor checked... no damage or signs of scraping
DUde, i have the same sound when driving in reverse. I thought it was a wheel bearing, but im starting to think its the struts. Ill be changing mine soon, so if thats it ill let you know.
were all the adjusments made correctly(both sides at the same exact height)? did it start happening as soon as the ksports were put in? did you put them in, or did a shop? rim offset and width?
take of your rim on the corner you think the problem is coming from and check the inside edge of the rim and all in the wheelwell to see ifanything is scraped.
