HELP
Old May 17, 2001 | 12:02 PM
plugboy's Avatar
Vehicle: 2000 Tiburon
Default HELP
I looked and looked and looked but I still can't find any rims I like..And when I do find a set I like, Im told that they wont fit because of the bolts holding the rotor. Has anyone else had this problem????? I really wanted the focal R3,,,,they would look really slick on my 2000 yellow tib. One place said they would fit while another said they wont...what do u guys have on your cars???? sad.gif
Old May 17, 2001 | 12:42 PM
accent 1's Avatar
Hey if the bolt patern will fit the car just check it see if there are some cut outs in the back of the wheel so that the bolts on your rotors will reces into the back of the rim alot of rims will fit the car you just have to check for those damn cutouts next to the bolt holes!
Old May 17, 2001 | 02:50 PM
If you have a 2000 Tiburon, you don't have any problems. Those shops don't know what they are talking about.
1999 and newer tiburons can fit any 4x113.5 lug pattern wheel.
It was only the 1998 and older that had the problem with the bolts.
Get the Focal R3's if you like them.
Old May 17, 2001 | 11:25 PM
:: skilspeed ::'s Avatar
Did you try out http://www.tirerack.com or http://www.discounttire.com ? They have some good looking wheels and at tirerack you can see them on the car.
Random nice sig!
