Drag Wheels
Old Oct 2, 2005 | 08:00 PM
tunershark87's Avatar
I was just wondering if the Drag wheels are any good, or if they bend esay? and if i wanted to go with 18s will 215/35's be ok on it ?
Old Oct 3, 2005 | 02:18 AM
KCVoRTeX's Avatar
pics? link? need more info man
18s aren't a good idea on tibs... lot of people run into problems with rubbing
Old Oct 3, 2005 | 04:03 PM
brian01tib's Avatar
I thought drag wheels were usually 15 inch with some thick slicks. Then the smallest wheels possible in the rear wit some skinny tires. For non drag Id put the same 15s with slicks in the rear. But for other racing you would want a stiff sidewall.
Old Oct 3, 2005 | 04:04 PM
guys hes talkin about DRAG WHEELS the company...
with 18s you will rub
expecially with that size
people rub with 17s in that size
Old Oct 4, 2005 | 08:07 AM
yeah im going to go with 17's now does anyone know what size tire i sould get?
Old Oct 4, 2005 | 11:14 AM
Viper966's Avatar
im runnin 215's on the front and i dont rub
Old Oct 4, 2005 | 11:46 AM
zoned019's Avatar
Vehicle: 97 Tib
unless you want your speedo to be off, you need to find a 17 inch "stock" equivalent.
the closest one is
205/40/17
Old Oct 4, 2005 | 11:52 AM
'treezy's Avatar
I say 215 is the max. I regret not going with 215's I played it safe w/ 205's.
Old Oct 4, 2005 | 11:58 AM
zoned019's Avatar
Vehicle: 97 Tib
... again, unless you want your speedometer to be off, get 205/40s. (thats IF ur getting 17s)
Old Oct 4, 2005 | 12:12 PM
'treezy's Avatar
speedo needle can be adjusted.
