Deep Cryogenic Tempering for rotors
Old Jan 12, 2003 | 11:24 AM
Jmontigny's Avatar
Vehicle: 02 Elantra
Default Deep Cryogenic Tempering for rotors
I have just about given up on finding rotors that are manufactured with slots only for the 01-03 Elantra. I am going to put some effort into finding a company to do the cryogenic treatment on the stock rotors. I am also going to make sure Hawk is the best choice for pads with rotors that are put through this treatment. And last I am going to look at the feasability for brake cooling ducts. The reason I am going to this effort is because I want to take the car on a road course but don't want the brakes to fail after two laps.
So far it looks like the process only costs about $25 a rotor and has an excellent record of preventing rotor warpage.
Old Jan 12, 2003 | 01:31 PM
Viper966's Avatar
ive put my tib through 6 back 2 back 2 minute autoX runs with full lockups from 80-30 on a strate away and i have yet 2 warp a rotor... why are u warping them so easily... now pad wear is another issue but no rotor warpage here
Old Jan 12, 2003 | 08:52 PM
Jmontigny's Avatar
Vehicle: 02 Elantra
Autocross is not the problem my rotors are fine now also from doing that. Try taking you car to 100 and braking as hard as you can to 50mph a few times and see what happens. I want the brakes to be able to handle the conditions a road course will put them under since I may try to go out on a couple this summer. The last thing I want is brake failure at the end of a 100mph straight.
Old Jan 13, 2003 | 12:41 AM
skierd's Avatar
Vehicle: 1997 accent L
I believe DBA (Disk Brakes Australia) sell slotted rotors in stock sizes for many hyundai's...
No opinion on pads, but you should really look at getting a set of pads just for track use. That way you can run a more heat-resistent pad as compared to a street car setup. I suggest ATE Super Blue (or Type 200) brake fluid, its got a wet boiling point of 400 degrees, and a dry point well over 500. Not sure the actual specs off the top of my head.
As for the cooling ducts, it should be a relatively straight shot from the front bumper to the wheel well once you cut a hole in the fender lining. Just aim the ducting that the center of the caliper.
Old Jan 13, 2003 | 12:54 AM
Jmontigny's Avatar
Vehicle: 02 Elantra
Everyone claims they carry DBA but nobody can actually get them.
Old Jan 13, 2003 | 01:06 AM
nking84's Avatar
call up team rip engineering or find em online. they cryo-freeze tranny's and gears for DSM's
