Correct Offset?????
Old Jul 17, 2001 | 10:49 AM
TJ Strickland's Avatar
Default Correct Offset?????
What does that mean?
Old Jul 17, 2001 | 11:03 AM
Canadian Prairie Shark's Avatar
An offset is where the bolts are in relation to the middle of the rim.
0 offset would put the bolts in the exact middle of the rim. A +40 offset puts the bolts 40mm towards the front of the rim. Big V-8 drag cars run - negative offsets which gives them that "deep dish" look.
I believe the offsets can be +38 to +45
Hope I helped.
Random can tell you exactly.
Old Jul 18, 2001 | 10:43 AM
KayJai's Avatar
Ok, here's a question,...
On 17x7's wheels, if the offset were 40mm, will it fill the well nicely?
And if they were 16x6.5's what offset will fill the well nicely? So they're not "tucked in"
Thanks
Old Jul 18, 2001 | 12:34 PM
KayJai, I have 17x7 with a +42 offset. I does fit the wheel well very nicely! They have never rubbed yet.
As to the 16x6.5 I am not sure but I would think that the offset would be the same.
Random I could use a little of that "infinite" wisdom of yours.
