Cheap Performance Tire
Old Jan 30, 2006 | 08:37 PM
MK3Design's Avatar
My tires are rapidly wearking down to a dangerous level >.<
I really dont have the funds right now for some super expensive tires either.
What are some cheap, but well performing tires? Links would be appreciated also.
I plan on keeping the stock rims too. What are the dimentions I need, what would look best also?
Thanks
MK3Design's Avatar
Thanks
Old Jan 30, 2006 | 08:43 PM
Kumho Ecsta 711's wear down much faster than Ecsta 712's ... I've got 712's on the rear and 711's on the front.
the 712's were on the front, then I got the 711's, put them on the front, and moved the 712's to the rear. I still have the same 712's(older pair) on the rear and the 711's(newer pair) on the front and the front 711's are already needing to be replaced.
www.tirerack.com does have pretty good prices
Old Jan 30, 2006 | 08:45 PM
mang the best cheap good performing long lasting tire ive found either the khumo 711s(pretty grippy got them on the mustang)
the 712s(what i have now on the e)
or the asx or the new stp
there all great tires
tirerack has them priced around 65 bux in the stock 15inch size
Old Jan 30, 2006 | 08:52 PM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
Try Hankook Ventus HR II's
pretty cheap, good grip. don't use them in the snow though.
my stock tire size is 195/55/15. but then again, Canadian turbulence gets a different rims than US spec. so you better double check.
http://www.1010tires.com/tire.asp?tirebran...entus+HRII+H405
hprockets's Avatar
Old Jan 30, 2006 | 08:54 PM
Spiffywerks's Avatar
StockSize : 195/55r15
Kumho Ecsta Supra 712: $61.00 each
http://www.tirerack.com/tires/tires.jsp?ti...re1=yes&place=1
17inch: 205/40r17
My Personal Preference and Tires I have: (if you want an affordable, SUPER STICKY tire.)
Kumho Ecsta MX: $100.00 each
http://www.tirerack.com/tires/tires.jsp?ti...e1=yes&place=19
They have a treadware of only 220, so they don't last for a very long time, but the performance is unbelievable.
http://www.tirerack.com/tires/tires.jsp?ti...re1=yes&place=4
17inch: 205/40r17
